Hello there..
Welcome to our forum...
Let me take a few shots to answer your question...
1. It won't slow your car down terribly but a little bit.
Heavier rims will increase your ride's unsprung weight hence you need more torque to propel your car. So as a result, your car won't accelerate that fast compared to lighter rims.
Again, however, if u simply like the killer look of the rims as opposed to be too deeply concerned bout other drawbacks such as slower ride, increased harshness, increased fuel consumption etc... then it's fine. At the end of the day, it's your choice
2. Since your car is heavier now, then your fuel consumption will go up but bear in mind that one's driving style is equally important. Not to mention also whether you tend to drive more on highways or mostly in the city. I am not surprised even if you have a 13kg rims but your fuel consumption is lower due to your mainly Highway driving compared to a car with 16inch rims but heavy city driving.
3. The rim weight is not exactly the factor that should concern ride comfort. It's the rim size (hence the tires) that is the culprit.
You should expect a harsher ride when fitting lower profile tires.
Bear in mind that the change in ride quality will largely depend on the tire size and pattern chosen. Some tire manufacturers produce tires with strong marketing emphasis on its silent ride bla bla bla..eg the Yokohama Aspecdb
So, my advice to you is...
Change the rims by all means and choose the right tires that suit your driving style and the key strengths they offer that suit to your liking
Hope I have answered your questions.
Pls post more Qs if you have any..
JacK![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
JacK
