2008 X5
liaoyuean
hi all,
just got my 2008 X5. but got this active steering light on. may i know if anyone solved this issue before?
seems like quite expensive...
ah wil
Re: 2008 X5
Is it intermittent or permanent?
If intermittent, it's likely not the active steering itself but some sensor (still not cheap to fix, but cheaper!).
Best to contact one of the sponsors in the workshop section for a check and estimate.
Re: 2008 X5
hi
thanks for the reply... the active steering light is on permanently and I had bring to workshop on this... the fault code shows:
eco valve. but my steering is ok... no symtoms of active steering is down. so now tryuing to figure out what is wrong. today another fault code was surface...
transfer case high temperature. anyone encounter this before?
thanks
Re: 2008 X5
liaoyuean;1110444 said:
hi bro...think my new case will be similar to your this.... can I know the damage?
thanks
About $1500 to fix it. I got similar quotes from 2 specialist workshops so it's about there.
They replaced the actuator, which is not cheap. But if there are no complications, it's a 2hr job to fix, although you should plan on leaving the car with them for at least half a day.
Re: 2008 X5
hi bro...my other workshop did an oil change for me at the 4X4... he say to see how 1st. if really still same den will go into details... as i just got the car for a few days so he said no spend so much 1st...
anyway..just an update...some workshop uses underhand means to earn more money... the active steering light was finally solved. W/s tried to change the steering gear pump, the steering rack... the eco valve.... all still the same fault code was still visible. so tot might be the ECU issue, therefore once open, found that the wires were tampered before. there for a re-do of the wiring and also resoldering...solve the active-steering light issue... i called my dealer... as the dealer now claims that they didnt know such issue.... think got no chioce liao....will proceed to CASE....
but driving it for the last few days....its really a good drive...only hate when its red-light....cos quite a slow pick-up.... however will try pedalbox later....my friend told me will help abit...
Re: 2008 X5
Bro, you now driving X5, a people mover, so got to give up the pick up speed. :)
But the best thing is you now can go over bumpy roads without needing to slow down. :)
Re: 2008 X5
Hi seniors, my car just shown this error code just wonder any seniors encounter before :9c26 third row seat heater. But workshop open up but can't find the item spoilt... Anyone to suggest?
Re: 2008 X5
Hi there I just took delivery of a 2008 X5 myself. So far so good but have only had it for a day.
I've got to say pretty good handling for an SUV. Or SAV as BMW wants to call it.
Re: 2008 X5
The E70 X5 is a good looking car, esp in Stormtrooper White :) - congratulations on your purchase!
Re: 2008 X5
congrts!! welcome to our X family.... for mine...its a great drive and a good people's mover....
Re: 2008 X5
Hi Guys (and Girls?)
In my previous rides (Audi A5 and before that the VW GLI) I had tuned the car's ECU (amongst other things).
Is there any place/ shop you would recommend to have this done? And which tuning brand is best?
Or is this to be avoided, in case it messes with the electronics? As I heard Beemers were pretty complicated on the electronics side of things.
Re: 2008 X5
Hi Mahakali - yup definitely a great car. Both our cars only have 3 years on the clock and although it's still early days, i may very well look to getting another X5 once the 10 years are up. I prefer the aesthetic look of the 2nd generation compared to the latest model though ....
Re: 2008 X5
Mine is 2011 so I have about 5.5 years left.
Think the lastest model has a good stereo system and adaptive internal led lights ....quite nice
Re: 2008 X5
Sorry my bad, can't count. Need to learn more about the new model. Actually I don't even know my own model ....
ultracelvn
