5 Care and Cleaning Tips for Newly Tinted Car Windows
Infratint Automotive Film
Trusted Sponsor
If you are likely to spend most of your time behind the steering wheel of your car, installing car window film is for you. Automotive window films serve more than just enhancing the exterior of your car for it also gives great car UV protection. Tinting the windows of your car can block up to 99% of damaging ultraviolet rays of the sun, which is considered as the primary cause of skin cancer. It can also block up to 65% of the solar heat that penetrates through the windows of a regular car.
With car window tinting, the last thing that you would want to happen is to get the tint damage over a short period of time since its installation. In order to make your automotive window film last long, it is important to know that some tender, love, and care is crucial!
Although cleaning the tinted window of your car may seem an easy job, it may become a challenge if you don’t know the proper caring and cleaning process. That is why we’ve listed some care and cleaning tips that you should keep in mind if you want your automotive window film to last long.
1. Do wait until your window has completed the curing process
No matter how bad you want to clean your newly-tinted window, it is important to note that you cannot do it right after you had a window tinting job. The main reason is that automotive films can take several days to totally complete the curing process. If you insist to clean to clean your window, hazy, streaky or blotchy appearance is likely to happen due to the moist that may form under the car window film.
2. Park your car in the shade while cleaning
Cleaning your car under a shady part not only does provide comfort but also contributes to an excellent cleaning process. The sun causes the cleaning agent to dry out easily, which makes it challenging to spread, soap up, rinse, and dry off your cleaning agents, there is a high chance of spot forming on your car windows.
3. Determine the product that can ruin your tinted car window
If there’s one cleaning agent to avoid when cleaning your tinted car window is a product that has ammonia. Using ammonia-based products is like putting your car window film in danger, given that it can reduce the darkness of your car window film, as well as cause its material to be prone to dryness, brittleness, and so on… In addition, avoid using abrasive products when cleaning your windows such as paper towels, newspapers, and scouring pads. Instead, use a soft cloth to wipe down each window.
4. Avoid your windows from getting scratch
If you’re traveling with kids or pets, it is important to keep your kid’s fingers and your pet’s paws from the window as these unintentional scratches can be the start of the peeling of an automotive window film from the glass.
5. Correct deformities and irregularities in your tinted car windows
In case you have spotted some bubbles trapped underneath the window film, it is suggested to herd the bubbles to the nearest edge using a credit card (or any card) wrapped in a soft cloth. By doing so, the air trapped between the glass and the window film can be released without causing marks on the tinted window.
If you haven’t already tinted your car windows, it is high time to consider looking for one of the best providers of car window tinting in Singapore. With this, Infratint can provide you quotations among the several automotive window film companies and help you determine the right window film for your car. You may contact us through our customer care hotline 6684 5330 or 9456 0888.
aceadvisory
