axl;331607 said:So you laugh whenever you see an 8MR izzit?
I guess when the Best Motoring guy said that this car is now ready for 2.5L he was pretty much correct. 2L car at almost 150ps/litre already at the manufacturer's limit for most purposes. The chassis is very sweet but as the target segment worships HP, Mitsubishi should do well to consider a light V6 in there. Trouble is I think they have no such engine ...TripleM;331760 said:ok bit like the M3, car much heavier in the chasis despite engine is lighter than the predecessor...
so all in all, the EvoX should be a good car (with good chasis) if the car is tweaked further..
Mitsubishi actually does have a few V6 engines the most famous is called the 6G72 which is pretty well known. It was used in the Mitsubishi GTO (Japan), also known as the 3000GT (US) and Dodge Stealth (US).centurion;331767 said:I guess when the Best Motoring guy said that this car is now ready for 2.5L he was pretty much correct. 2L car at almost 150ps/litre already at the manufacturer's limit for most purposes. The chassis is very sweet but as the target segment worships HP, Mitsubishi should do well to consider a light V6 in there. Trouble is I think they have no such engine ...
Hi Crufty, there was somewhere I read and lazy to search now, that the Mitsu V6 engines are pretty heavy and probably will affect the Evo's balance .... as for the power, i've recently found a statement by Ben Oliver (Car) which is quite relevant to my thinking: More power is seldom a bad thing, but it's much more satisfying to stretch an engine than constrain it.Crufty Dusty;332105 said:Mitsubishi actually does have a few V6 engines the most famous is called the 6G72 which is pretty well known. It was used in the Mitsubishi GTO (Japan), also known as the 3000GT (US) and Dodge Stealth (US).
re: "worship HP" that's a generalization that applies to all car enthusiasts, it's like money, hard disk storage capacity and RAM... too much is never enough. The platform has been proven for many years with commonly available parts... no need to significantly change a winning formula unless required by law or environmental concerns.
It's a classic engineering problem: maximize power, fuel efficiency and reliability with low weight, cost and environmental footprint. If anyone can fulfill all criteria then there will not be a need for further engine R&D. Everything involves a compromise, it is only to the extent to which one can be satisfied.centurion;332142 said:Hi Crufty, there was somewhere I read and lazy to search now, that the Mitsu V6 engines are pretty heavy and probably will affect the Evo's balance .... as for the power, i've recently found a statement by Ben Oliver (Car) which is quite relevant to my thinking: More power is seldom a bad thing, but it's much more satisfying to stretch an engine than constrain it.
stretch= rev an engine to real high, shift, repeat, and yet not be too much beyond the lay. work the engine hard and yet manage the speed. Not stretch the engine to higher and higher HP...Crufty Dusty;332161 said:It's a classic engineering problem: maximize power, fuel efficiency and reliability with low weight, cost and environmental footprint. If anyone can fulfill all criteria then there will not be a need for further engine R&D. Everything involves a compromise, it is only to the extent to which one can be satisfied.
re: stretching an engine, how far do you want to go, and how much are you willing to pay for it?
