Advise needed: 18 ACS type 3 can clear 330mm rotors?
mybmmer318
As above, planning to upgrade my brakes to either 4pot or mini 6 pots( taiwan calipers + 330mm rotors) was wondering if after install BBK can clear 18 inch ACS type 3 rims(1 pc type)? Any bro done this and whats e offset for the ACS 3 rims? Thanks.
Re: Advise needed: 18 ACS type 3 can clear 330mm rotors?
No problem.. It'll definately clear the rotors..
Thks for e advise..i believe calipers should clear the ACS as well? Any idea is the type 3 offset 36? thanks.
it's +38 if i remember correctly.
what calipers are you using?
Considering e-spec calipers from taiwan..still no cfm yet or maybe try Silent house brand calipers..budget constrain.haa
you'll have to ask yourself why you're upgrading to BBKs in the first place, especially if you're on a tight budget.
the stock brakes are good enough for street driving. if you're going to the track, upgrading to 330 brakes should be sufficient.
yup.. 330 brakes is gd enuff..but 330 brakes are even harder to find than regular BBKs.. well still studying the best set up if not will stick to stock brakes. Anyway thks for e advise!
When a Tiger comes
bump up lurkTwo guys were walking through the jungle. All of a sudden, a tiger appears from a distance, running towards them. One of the guys takes out a pair of "Nikes" from his bag and starts to put them on. The other guy with a surprised look and exclaims, "Do you think you will run faster than the tiger with those?"His friend replies: "I don't have to out run it, I just have to run faster than you."--------------dvd copy,--------dvd ripper, ------------------dvd to ipod,----------------dvd ripper,-------------------dvd software,-----------
ACS 18" rim will clear the 330mm rotor, mine is on 18" rim with 338mm front rotor
Your reply is 5 yrs late
Late reply is better than no reply. Maybe owner was driving VW now and queueing for repair his tranny.
Happy New Year 2014!!!
And thinking about his ex ride ....
Hi, is Benjamin Sheares still the President of Singapore?
I am going to protest against the merger of SG and M'sia. Ccb gahmen
Some more complaint PAP , they will hire najib + rosmah to rob more money from you.
today my company hock lee bus will go on strike.
