Airbag light is constantly on
Blue Steel
Any experienced bros here knows why the airbag light is on? I was told it can be fixed by reset? :errmm:
Thanks in advance to any kind soul that can solve my problem.
E85 Blue
Re: Airbag light is constantly on
better get it checked for safety sake. there are cases of folk going to do audio or sound-proofing, end up accessories shop trigger air bag to blow but keep quiet and stuff it back in. there won;t be any airbag to save u in case of accident in that happened
Wah sian, hope its just the sensor problem reset can solve :p thanks for the heads up, btw I saw jerms' headlights damn chio you got carry? :)
Hi all,
Airbag light issue is resolved. Went to my workshop and apparently the fault code is some passenger seat belt tensioner.
Just click the wire connector under the car seat in place after clearing the fault code its back to normal.
This WS quite experienced ....... glad you resolved your problem.
Blue Steel;931488 said:
Hi all,
If it comes back on, ask them to pull it out a little so there's some free play before reconnecting.
The connector can get loose easily when you shift the driver seat often so more free play avoid this recurrence.
Hi all,
Seeking advice from fellow forumers. How do I disable the front or rear air bags? Mine is a 2006 E90 323i. Thanks in advance.
Do you have the manual with you ?
Mine is 2nd hand car, with no hardcopy manual. I checked the softcopy available online, but it doesn't mention how to manually disable the airbag. Rather it said the sensor will tell whether the passenger is child or adult, and then activate or deactivate automatically.
then why would you want to disable the airbags?
working on the car's electronics and worried that the airbags will trigger?
Going to put my child seat on the front passenger seat, and don't want to leave it to the sensors and electronic circuits to decide for me. Thought if it can be activate/deactivated easily, it will be great.
That's one way too... trigger the airbags and they'll be disabled!
Auto deactivation - adjust child seat till you see the deactivation light lit
Or else as per Oilman's suggestion
if I am not wrong, there are instructions in the owner's manual on where and how to put the child seat.
child seat should be put in the rear, not in the front passenger seat.
I also recall that children below a certain age are not allowed on the front seats, even with child seats. People with kids like brobot and tobynik, pls help out...
Thanks all for the comments/suggestions. So the conclusion is there is no simple way to activate/deactivate the airbag. I guess case closed. :)
bet69help
