Alternate brake pads replacement for E89?
Demiblade
Guys, I was having my E89 serviced at PML today, and was being told by the CSA that my rear brake pads need to be replaced soon in about 10,000km for $500+. My car is currently at 24,000km mileage, still under PML warranty, and has 18" stock rims.
1. Is this normal to wear out the stock brake pads at 24k? I am not the most gentle driver around, but I definitely didn't abuse the brake or track the car.
2. I am eyeing some big brake kits, together with a new set of rims+tyres. I know it sounds stupid to spend like 20 times more instead of having a simple brake pad replaced, but I am quite poisoned after seeing the souped up bimmers here. :woottt: I know BMW performance brakes for E90/E92 fits an E89 for the front fine. I also saw 4/6-piston Brembo big brake kits. But all of those seem to be for the front only, what do u guys normally do about the rear brakes? What are my options for after market brake setup on an E89?
Re: Alternate brake pads replacement for E89?
the stk brakes on ride def not confidence inspiring.
if u mod the rear brakes (as in new rotors n calipers like brembos), your hand brake is no longer usable
can u live w that?
i think most just change front to BBK n rear just change to aftermkt pads like EBC so that we still have hand brakes when required
i myself havent tried it yet, changed front to 4 pot brembos n waiting for the below to arrive next mth
http://cgi.ebay.co.uk/ws/eBayISAPI....&ssPageName=VIP:watchlink:top:en#ht_845wt_932
ac323 comments pls?
can u live w that?
EBC REDSTUFF BMW Z4 2.5 (E89)(23) 09>2010 REAR BRAKE PADS DP32046C | eBay
ac323 comments pls?
on local road, upgrade the front should be very good already since must forgo e-Hand Brake if install a 4pot in......( for rear )
alternatively is to upgrade to better brake lines for rear then front upgrade to BBK......
( no need to drive so fast so many cam on SG road )
drive safe
cheeeeeeeeeeeeeeeeeeeeeeeeeeers
I want 4pot front!!! But no budget now! :(
Look out for dekit.............( should be more affordable )
cheeeeeeeeeeeeeers
cheeeeeeeeeeeeeers
Yup! I am looking for dekit sets... Does e90 or e46 4pots fit onto ours?
Thanks guys, looks like we are pretty much stuck with stock setup for rear. I don't want my car to roll down Mt Faber by itself when parked without the e brakes!
Those on 4pot front, do u have any feedback on brake bias? I thought our z4s being 50:50 weight distribution, the front and rear brake components should ideally deliver torque in the same ratio as the front-to-rear weight distribution, i.e., same.
i think thats reason y brembo GT for z4's front is designed 4 pot rather than the std 6:4
seems pretty ok
I need to buy front and rear brake pads, brake sensor and brake discs.
Please let me know if anyone is selling, or if there is a group buy organized.
[email protected]
Thanks
[email protected]
Thanks
if yours is fully stock brakes then go get a new set ( brakes dont play )
* you looking at used Brakes???
cheeeeeeeeeeeeers
ok will get a new set.
How about fog lamps and transmission fluid? Any Group buys organized?
group buy abit tough for fog lamps and transmission fluid........
cheeeeeeeeeeers
Actually whats the kinda discount we get for group buys on BBK?
Can we organize a group buy for BBK? for those who are still om stock...
Or its done and over and everyone has it already?
Year end coming... BONUS
gemwinrestauranteclubcolo
