Battery
allenng
Hi Guys,
i am driving a E93 325i with idrive. I cant seems to find any function that shows the car battery. How do we know the battery is running low. I had some bad experience with my previous few drives with car battery. They just suddenly die on me. hahha
Re: Battery
I can't help you with an answer. But I do want to comment on the issue of changing battery....
For 3er and 5er, you don't need to go to PML to change battery..... PML told me once that my 5er MUST use original BMW battery or risk damaging the car computer - very very serious problem. And the PML battery is $800, excluding labour.
I got a VARTA outside at about $300.
Re: Battery
And when my key with comfort access failed, they quoted me $35 to replace battery..... original BMW battery.
Re: Battery
One month ago, as part of servicing, PML quoted me $1200 for four sets of brake pads..... hmmm..... how to build relations with agents like this....
Re: Battery
yea they charge me $1200+ for servicing and changing brake. Best is they change my front rotor without asking me
Re: Battery
Get a Scangauge to monitor your battery's voltage. Aftermarket batteries can look for fellow forumer Gadaffi, his Ody range.
Re: Battery
allenng;675877 said:
Hi Guys,
to be sure, u can use a voltmeter to check the voltage reading on your batt.
a fairly accurate layman's test is to monitor cranking to start the car. if ur car takes longer than usual to crank, it's usually a sign ur batt will kaput soon.
Re: Battery
i did a batt change @ PML recently, i paid just below $300 for it. I'm driving a E90 btw
Re: Battery
Thank you KENN
Re: Battery
your iDrive should show "Increased Battery Discharge"
just had my batt replaced at PML last week... heng its still under warranty so FOC
Re: Battery
A Scangauge can monitor the voltage....... before the voltage dips......
Re: Battery
What is the rating for E90 320i battery? 65A or 70A.
Will change to a bigger 80A battery better?
Re: Battery
more won't cause a problem, but less will cause your car not to start
Re: Battery
I tot is like $500-600 to change at PML? Below $300 is quite reasonable if change at agent
Re: Battery
Interesting... May I know how much, when to buy and how to install?
Re: Battery
Check with BVO. I recall it was around $250-300.
Re: Battery
Wh0cArEs;676681 said:
i still have the receipt if u need proof :lol:
Hi, is the battery replaced by PML same as the factory fitted type?
I think I need to replace as my cranking in the morning seem weaker now..
pg88comim
