"bee" sound when accelerate
tngtony
Recently whenever I accelerate I hear a whining noise coming from the dashboard area.Any one encounter this problem too?
Re: "bee" sound when accelerate
tngtony;876831 said:
Recently when I accelerate I heard a bee sound coming from the engine area.Any bros ever encounter such problem?
Engine area or dash board ?
Bee in dash board.... POWER! Maybe try and spray some Shelltox inside?
it may be from the fan within the IHKA panel (aka aircon control unit)....but im not expert
IT'S like when the car audio system is not wired properly the speaker will give out that whin sound when you accelerate.
Hmmm.....seems like we have a similar issue here. The sound only comes when accelerate, especially noticeable when the vehicle is on stationary and start picking up speed. To me, the sound seems like a small piece of paper flapping like that. The sound seems to cone from the front/dashboard/front side fender.
I haven't sent to a workshop to haven't it check. But I think it's quite difficult to narrow it down.
Does it sound like an airplane?
Yes it sounds like an airplane. Ppl used to call it airplane sound.
Did you do any wiring work recently? Audio or otherwise... Does the sound still exist if you mute or turn off the sound system altogether?
mine also have saome sound... while accelerating... even when leasing the throttler the will occur upon downshift >
Mine also got this sound...im suspect come from the aircon...like paper flapping or like vibrating...so irritating!
Have similar problem... gona send to workshop soon. hopefully can zoom into the source.
If is the whinning sound, it may be the rear axle, my buddy also just replace the rear axle for 3.4k.Now swee swee no sound
Hi all Bros, You may try switch off all your audio device and try to listen issit the Bee sound or eeeeeee sound coming from the back. If it so, you maybe facing the same problem as me. That is your rear axle worn off sound. I already change mine and now start to enjoy my ride with no Bees flying inside... Hope this can help....
Cheers and good luck..........
99okmeme
