kon;951313 said:Is this the first time you pair a phone to the same car, or you've pair another phone previously and it's working fine?
If this is first time, then in the idrive BT menu, make sure you selected "audio" to work with the phone. Depending on your car equipment level, you can typically select Phone, Additional Phone, Audio & Data.
If you used it with another phone before, then check your phone settings to make sure it allow audio streaming.
P/S: only applies to F20, if EXX, then not applicable to you
lmhdex;951335 said:this is first time I've paired to a phone. I'm quite a noobie here. Which screen to go to select audio streaming on?
kon;951590 said:Manual http://f20.1addicts.com/forums/attachment.php?attachmentid=797763&d=1355853796
read/follow instructions from page 200 onwards...
Otherwise, call your sales to teach you, he should have done it when you collect your car anyway![]()
Red_Bean_Bun;951707 said:Got check the volume ? Phone and car ?
lim_ck;953626 said:does your car comes with A2DP bluetooth streaming functionality?
lmhdex;953905 said:You mean the A2DP streaming is not default built-in and must be requested when you buy my BMW 118i?
Must I go back to performance to request for it?
