BMW Coolant Temperature fixed at 126deg C, is it true?
Racebred
Core Group Members
unless there's a heater that's on all night! hahahahha!! you cannot expect the water temp to be 126deg all night right. :)
anyways, it's always good to warm up the engine. From a cold start, the water temp is at ambient temp. The when the needle moves to the edge of the blue zone, it's 60 degrees C. When it reaches the middle point, it's 75 deg. Now the needle movement is not linear. At temp range from 75 to 125, the needle stays in the centre.
Normal operating temp for our car is about 100deg. +- 5, depending on whether you are cruising, waiting at a traffic jam, going fast and furious, etc.
at 126 deg, the water temp is considered slightly higher than normal, as usually at the traffic jam it should not go above 110 also. Only at the track will you hit such temperatures.
A proper warmup is essential for the longevity of the engine. And as you can see that the needle hits the middle mark about 25 degrees before the engine hits optimum temp (75 deg compared to 100deg), you actually have to slowly warm up the engine a couple of minutes more after you see the temp needle hit centre.
It's actually a very high pressure system, and I should point out that one should only open the radiator cap before a cold start. Even if you have switched on your engine for 30sec, dont touch the system and open the cap anymore. Wait for the next morning to check water level. This is as advised by the technical guy in PML.
Even though we are talking about coolent temp here, and not engine oil temp, it's a good enough gauge to see engine oil temp, as their temp seldom varies more than 5 deg C. So pls remember to start gunning your engine a couple of minutes after your needle hits centre. Try to keep the engine rev low, say about <4500rpm. You can drive off immediately, just dont rev it too high.
As for coolent, it only helps to raise the boiling point of water, and gives it a lower heat capacity, so that it can lose the heat faster. I dont think it can help stabilise the temp at all times, much less at an undesirable 126deg C.
hope this helps!
Thank you, thank you very much.
Alot of good knowledge here I can learn...
P/S: Will 'get' that BMW friend of mine when I visit JKT week after next...hehe
And it has definitely helped..
Cheers,
To Racebred, do we need to warm up the engine the next morning b4 we move out from the parking lot after we left the car the previous night? I used to warm up the engine until the needle is over the blue portion. But i read from the car manual that we shouldnt do tis. Instead we shld drv off immediately after we start the engine but at a slow speed n low rev. Confuse :thinking: :thinking: . Ur previous advice?
I think Racebred meant its better to get car warm-up first pass blue mark. But its ok to drive off immediately before warm-up but try to keep a low rpm. Brother, pls correct if this is wrong...
Sometimes its hard when you in a hurry in the morning esp. when you are late for work. Hard to keep low speed and low rev....
Like this morning, heavy rain and overslept... :( :(
Yup i noe, tats y sometimes need to juggle between the rush of time or the extra care for our baby bimmer ;)
Yes, as stated in the manual, best is to drive off immediately after you fire up a cold-start. But keep the rpm low till the temp needle hits middle. Best is wait for about 2-3 minutes more AFTER the temp needle hits middle.
Of course if you really need to gun it then just do it. Usually we want to have more mechanical sympathy for our beloved cars but if you're really boh chap and want to sell your car after 2 years then do whatever you want hahahaha. I once redlined my car in the cold, in a merc, and metallic smell came in through the aircon. hahahah
I think all Mercs have that smell when you redline it when they are cold... I have the same experiences as well. Hehe
The reason why the manual advised to move off straight away instaead of sitting there for warm up is that in a idle warm up, only the engine gets warmed up properly while the rest of the parts like the transmission and rear diff is not warmed up properly...
So, by moving off, but keeping the revv at moderate rpm, u will warm up the car nice and smooth.
The other issue is of course the fact that some ppl actually warm up their car in their garage and get themselves killed byt the carbon monoxide so the manual needs to cater to a wide spectrum of ppl...
primedentalgroup
