Weights are similar. Go to BMW North America to compare models with the same engine - 328 coupe vs 328 sedan, 335 coupe vs 335 sedan - you will realise that weights between e90 and e92 are similar.uupizwm said:Btw, isn't the e90 320i the same weight as the e92 320i?
Yes, if you go to www.bmwusa.com to compare weights of sedan vs coupes in all the same engine categories, they are all almost identical.uupizwm said:Btw, isn't the e90 320i the same weight as the e92 320i?
Yes, if you go to BMW North America to compare weights of sedan vs coupes in all the same engine categories, they are all almost identical.uupizwm said:Btw, isn't the e90 320i the same weight as the e92 320i?
acupunch;363021 said:congrats on making up your choice. ok! ai MOD mai.
commonly what most ppl had done on their E92,
Window Tint,
BodyKit
E92///M3 Mirror
E92///M3 Steering
Muffler
Brembo BBK
Coilover
Staggered Rims
CSL boot
BTW what color combo you're eyeing le?
acupunch;363030 said:mai replica la. cos i heard its quite heavy wo. what are you're alternative choice of 'LIM'
SG w/Red in wooo. Kenn's twice ah! good good. I think so far I've not seen one other than Kenn's.
Happy modding. BTW, when is your delivery date?
The original E92 M3 rear rims have very different offset from E92 non-M, and hence I have seen few E92s running on M3 reps - but I suspect they are running on 4 of the front wheels instead of a staggered set-up. As such, there is no concavity at the rear wheels.uupizwm said:I kinda of like the concave look on the m3 rims.. unless u hv another recommendation?
kenntona;363037 said:Rims are very subjective, and it will be easy to start with 2 questions - size and budget?
2 choices:uupizwm said:But if it aren't too exp like say 6-8k per set.. i am still ok..
acupunch;363040 said:to be concave you had to go for staggered set up. some recommendation.
VMR V710 Wheels by Velocity Motoring
Breyton GTSs
