BMW F30 328i came by to sort out his Fuel Tank. This has become a common issue for some of the F30s.
This particular fuel tank has been repair by the previous owner but as u can see still leaks badly! Better be safe!
BMW F30 came in to sort out his leaking fuel tank.
We have so far seen quite a fair bit of leaking fuel tank in the F30 series. Make sure you do not squeeze in too much fuel at the pump. Some of us like to squeeze till the brim and cap it tight. When fuel expand, the tank cracks.
BMW F30 328i came in to sort out his leaking fuel tank issue. It is becoming quite a common issue. If your car is having this issue, u should be able to catch the petrol smell when u top your ride with a full tank.
Thank you for the support!
