endless
Features
BMW Scanner V1.3.6 is a new version of BMW scanner intended to work with BMW 3, 5, 7 series and X3, X5 SUV cars.
Package Contains
Driver cd
diagnostic adapter
cable with BMW-20 connector
cable with OBD-II connector
RS232 cable
Main Functions
[FIND UNITS] -scanning installed units with reading identification data and malfunction codes
[CLEAR ERRORS] -reset fault codes in all of found units
[ERRORS DETAILS] -detail info about malfunction codes
[READ MEMORY] -reading unit software memory
[READ EEPROM] -reading EEPROM in units: IKE, LCM, ZKE, SRS, LEW, A/C, VID, BMBT, STH, AIC...
[WRITE EEPROM] -writing EEPROM in same units
[ERRORS] -reading detail info and reset malfunction codes in selected unit
[RESET UNIT] -unit software reset
[WRITE FGSTNR] -identification number writing
[WRITE ADFG] -more identification data writing
[ODOMETER CORRECT] -writing new mileage value to IKE & LCM units
[SAVED ODOMETER] -reading more detail info about mileage from IKE & EGS units
[SERVICE RESET] -IKE service reset
[CHANGE LANGUAGE] -changing language of main computer messages GE/EN/FR/IT
[FACTORY DEFAULTS] -factory defaults reset of IKE & LCM (for cars till 1999 year)
[COPY CODING] -base coding copying IKE to EWS or EWS to IKE units
[TV FUNCTIONS] -"video on when driving" setting in VID unit
[READ KEY] -reading ignition keys data from EWS unit
[ADAPTATION LEW] -steering wheel sensor (LEW) adaptation
[REGISTER HANDSET] -new handset register to TEL (BIT2) unit
Supported Models
List of supported IKE & LCM modules
IKE
BMWTNR HW SW EEPROM-IDNR
selling at $100/- pls call hp83033300
Package Contains
Driver cd
diagnostic adapter
RS232 cable
Main Functions
Supported Models
IKE
