wt_know;663316 said:if less brake dust is what you are looking for, the answer is cool carbon brake pads. i'm using them.
check out boss thread, not sure got application for 320.
just you know, it squeek at low speed and has clik-clak sound at rear (double confirm) after 10k-15k+ milleage. need to service the brake, then ok
denniszz;663325 said:Today @ BVO, they advise me to use back original brake pad... other in the market not so effective when braking... dunno true or not...
How much is the cool carbon brake pads?
davidtch;663418 said:It is an LPPL question.
Low brake dust = harder brake pad = Increase in rotor wear
High brake dust = softer brake pad = Less rotor wear
garbage888;663401 said:I am using EBC green on my E60.
Brake dust very much reduced compared to stock and braking / biting power is there.
Only got the squeak sound in morning / wet conditions when low speed braking or parking, but is acceptable to me as this is also evident in the stock brake pads.
I got mine changed at R2D
jinooi;663444 said:not entirely true...
try out the EBC Green pads. as good as, or even better than stock - less dust, and same performance.
tried and tested.
if you are have a more aggressive driving style, then try the Yellow or Red.
pricing is also very competitive.
jinooi;664385 said:call again later in the evening. they open after 6pm.
jinooi;664389 said:make an appointment .
your car will get more attention when you make an appointment cos rodney has more time to work on your car.
denniszz;664393 said:Took leave tomorrow... plan to service tomorrow... SMS them on Tuesday... say Friday close... i hope they can service my ride...
