Steve80;795781 said:Hi bros and sis,
How do you feel about the braking capability of the F20? During the test drive i actually find the braking to be a bit on the "soft" side. Wonder any of the bros and sis here share the same consensus?
jasonmaxima;795818 said:if you feel F20 brakes buay jiak.... upgrade SSBH... stainless steel brake hose and MAYBE aftermarket pads with more aggressive pad compound.
but aggressive pad compound would wear stock brake rotors faster
you dun need ultra racing high temp brake fluids if you are not tracking the car cos these fluids must change EVERY year as they are hygroscopic....meaning they will absorb moisture / humidity and degrade fast.
same OEM brake fluids or 1 grade higher is enough.
Steve80;795797 said:Am on Jetta Sports. Is the rotor and brakes bigger in size as compared to the F20 as I feel the current ride more "jiat". Stock brakes by the way..
Forrestgum;795835 said:JS using the GTI brake caliper and rotor at the front. Can't compare... SSBH and good pad will do the trick for non track cars.
Steve80;796063 said:Icic... Yeah agree that BBK a bit of an overkill since I do not drive that fast alsoJust looking at enhancing the braking capability of the ride
