Can 18" Star spoke 189 Rims fit onto E46
Amk88
Found a set of used 18" Star Spoke 189 rims on conti contact CSC3 tyres but the specification seem odd
Can get feedback from bros. if the rims can fit E46 with sports suspension set up.
My current rims is 17" Model 68M = Front 17x7.5j offset 41(Tyres = 225/45R17) Rear 17x8.5j offset 50 (Tyres = 245/40R17)
18" Model Star Spoke 189 = Front18x8j offset 34 (Tyres = 225/40R18) Rear 18x8.5j offset 37 (Tyres = 255/35R18)
Appreciate feedback. - THANKS
Re: Can 18" Star spoke 189 Rims fit onto E46
the 18" setup you mention will most like rub yr fender,that is the OE spec for E90
but if you does not mind rubbing go ahead
189 on E46 M, yes. E46 non-M, no.
Hi
Thanks for the feedback.
E46 M ? . are you refering to E46 M3
My current ride is the last batch of E46 Sports Edition. (318I)
Amk88;557631 said:
Hi
your current wheel specs only for E46.
not for E90 and E46 M3
again the second spec can not use on your ride
nohudoithuong2
