* CCD Car reverse camera
four_eggs
*** Left 2 sets only.
Imported Branded (manufactured by "SHARP") Wide-Angle 120 Degree WATERPROOF CCD Car Rear-View Reverse Camera. Excellent picture quality using CCD technology used in modern Digital Cameras; AUTO Back-light compensation to produce sharp pictures when in dark areas; Comes with angled lock rings to adjust the vewing angle. Connect to your LCD monitor for a complete reverse parking system as seen on latest Lexus GS300 & Cefiro.
S$150 per piece for camera only. Contact 96678989 / view picture at http://community.webshots.com/user/allentoh
Re: * CCD Car reverse camera
Can this camera work with Alpine D310?
Hi four_eggs, any chance this camera can be hooked up with the idrive on a E60? that'll be cool!
BTW, you're 2 eggs more than me hur hur :D
More like 3 eggs right? Wow if it can be hooked up that'll be awesome.
Cool...can it be hooked up to the e39 GPS system that I have al??? :)
Four eggs, diameter of the camera look big. Can it fit below (inside) the handle bar of the boot? There are two rectangular number-plate lights there. I want it for 318i Sport Edition 4-door, Oct 2004.
Hi - I'm very interested as my unit is ready, and just waiting for a camera to plug in. Some queries that I hope you can help with:
1. What is the resolution of this camera?
2. From the pic, I see two connectors. The yellow RCA carries video signal, but what is the black for? Power?
3. What is the mounting diameter of the camera body? I'm thinking of replacing the trunk keyhole with this cam.
4. Will there be any demo available?
Hi four_eggs,
It is interesting. Can this be viewed on the standard e60 display or need to add in additional display? If through the use of standard onboard screen, would there a need to modify to switch to camera input when reverse gear is engaged ?
Yankee
does it come with the rubber ring for water proofing like the Cefiros?
hb88covn
