matt07;188012 said:thanks guys
i m currently using the stock 17" rims with runflats. i was thinkin of lowering the car after changing to a 18"
is that reccommended?
sam;188795 said:am on the lookout from upgrading mine from 16 inch stock to 18 inch rims for E46...
Some dummies question that I have:
1) don't need to lower ride rite?
2) don't need to change brake etc,
3) harder ride, do you mean it is less bouncy and u could feel the road more or?
4) the extra wheel (does people normally buy an extra one to match the new size rims install vs still keeping the old spare ones in the trunk (which is not usable as it is of a different size 16 vs 18in), how do bros overcome that.
thanks in advance for the tips before I slowly venture into changing my rims![]()
chickenbackside;188804 said:1) No need if you choose not too, but will look much much much much better if you do.
2) No need cos you must be using stock brakes if you're asking this.
3) Yes, you will definitely need more road. You can overcome this by changing your shocks to Koni FSD's
3) Your spare tyre will till be useable. It's not meant for you to drive fast or for a long time with. It's just for you to get to a tyre shop ASAP so that you can still reach there to solve your puncture. Even your stock rims is already bigger than your spare. No issues there.
Like what a few people here said, go 19"s once and for all if your budget permits. It will make a HUGE visual difference compared with 18"s...
Azrielsc;188321 said:Change to 19" or nothing at all! That's my motto!![]()
matt07;188424 said:thanks gurus... what about the offset though i ve been getting different figures from leong seng , hurry and PML. are there any other factors i shoulf consider when i m shopping for rims?
TripleM;188889 said:Offset figures are not fixed for a particular car. Typically, deviation of +5 to +7mm from the factory measures are acceptable.
For your car, the stock offsets should be +34 front and +37rear for 8J and 8.5J widths respectively so u work it out from there. Most likely than not, u will be getting 8.5J all round if you are not going staggered so look out for offsets ard +35 all round..swee2x
If u want staggered set up then must play with the offsets n widths to ensure proper fitment.
