piggyboyz said:Check your connector to the the bulb housing, it's a common E46 problem. Take out the connector and u should see some arcing of the connector, causing the intermittent fault.
Get PML to replace the connector if it's under warranty, else a simple way is to gap the connector a bit to improve the contact.
It's prob not the reverse sensor that cause the fault.
