Cigarette Power Socket Not Working
Zak
Hi Bros,
I have the above issue on my E92 325i coupe. The power socket is located inside the center armrest.
Have changed the fuse but still not working.
Any advice ot there?
Thanks Thanks
Re: Cigarette Power Socket Not Working
Maybe loose connection. Have it check when you do your next service
theimperialdragon;1103806 said:
I have the same issue too. Tried changing the fuse in the glove compartment but to no avail =[
Which is the fuse and where's it located?
The fuse box is located behind the glove box. It contains around 50 fuses for all electrical-related items in the car.
Google "E90 Cigarette Lighter Fuse" for clearer instructions on how to replace.
You can buy replacement fuse parts from automotive shops.
They cost around 50 cents to a dollar each.
Make sure that the amperage is correct before making the purchase.
My ride is 320i. Actually tried to locate the fuse at the glove compartment but dunno what's the amperage of the fuse and the exact one. Maybe a kind bro can shed some light.
actually there is a piece of paper with the diagram layout of the fuse box.....amperes should be stated there.
what year is your 320i? sedan or coupe/cabrio?
pg88comim
