DINAN
totoseow
Legendary 10 Years
did a web search...seems like they developed quite a bit of mods. who carries it here?
nobody. you can bring them in yourself. the dinan sock and the EGS reflash seem to be very interesting.
Ok.. before you do that, you need to know that Dinan is a US company and as such tunes for US spec cars which are different from cars here... some parts will not fit in Singapore cars.
Headers is one of them, but also there are other things to look out for as the engine layout in the US spec is quite different in the Singapore spec. This is for sure.
yes... got difference... your steering column is in different position mah... so naturally your engine layout will be different also.
other than mirrors, not much lah. air intake, brakes, rims, suspension bodykit... all are universal.
of course interior trims wouldnt be the same. The ecu cannot be used too, but i read somewhere dinan does have ecu for eurospec cars.
Yes they do, but you need to send the ECU to them to retune. its like an exchange policy.
hb88covn
