DIY - Power Steering fluid flush
Red_Bean_Bun
One of the most neglected and one of the most used component of the car is the steering system. And that is assisted in most cars hydraulically (with the exception of a few models like the E85 which is electrically driven).
Hearsay neglect would result in noisy pumps and a heavy steering. Seals would harden as well.
My ride was making noises at full lock like this - you may need to turn up the volume - Sounds like a growling dog.
[video=youtube;Mc0Mjr9kPJw]http://www.youtube.com/watch?v=Mc0Mjr9kPJw[/video]
So from past experience - it just requires a top up and so I thought.
Popped the bonnet and looked for the power steering reservoir -
Double check what fluid to use -
Cap says CHF11S.
Check the existing level as per the WS manual - fluid must not be over or under filled.
Mine is below the minimum -
As a precautionary measure - I extracted the fluid to check the color.
This is what I found -
The color as you can see is Brown.
That is something very wrong. This is because there are 2 fluids used for the power steering fluid for BMWs - Either
- ATF (Red in color)
- Pentosin CHF11S (Green in color)
Here's what red ATF looks like -
The ATF as a PS fluid is dated. And BMW now references the Pentosin as the current fluid of use.
A quick reference to the manual confirms that mixing the 2 fluids is not recommended -
And my teacher in my NTC 2 did mentioned before - if you mix red and green - you will get brown.
So I have 2 problems -
- the fluid is low
- more importantly its mixed up
Likely by the PI dealer's WS.
2 approaches possible -
- just deal with the fluid in the reservoir
- replace the entire reservoir
I decided that I could get away with just flushing the reservoir - It should get me at least get a 90% thoroughness with 3 flushes.
But being that the reservoir holds about 300ml and since I have 2 litres of CHF - I could do 5 flushes and get more than the 90% I was looking for. Also the CHF caps are not re sealable anyway so might as well use all of it ........
and here's what is needed -
1 Big oil baster ($20 from Isetan kitchen dept)
2 Tins of Pentosin CHF
1 Measuring flash
The key tool - has a stainless steel body
DIY Starts here -
- Open the cap -
- Squeeze the rubber bulb to expel the air BEFORE sticking the oil baster into the reservoir. Do not introduce air bubbles into the reservoir.
- Pump the fluid out into the measuring flask. Keep doing that until the reservoir is empty. The white plastic is the filter at the bottom of the reservoir - seeing it means it is close to being empty.
- Pour the CHF into the reservoir with a steady hand - no bubbling if you can.
- Replace reservoir cap
- Get into the car
- Start the car engine
- Turn your steering wheel left and right full lock 10 times
- Turn off the engine
- Repeat the from where the "DIY starts here" header above 3-5 times depending on how much CHF you have or how thorough you want it to be.
After the fifth flush - top it up and make sure the level does not go over the max line.
Another way to see it is to not cross the line inside the reservoir -
Here's how it looks like after Flush no. 1 -
Left is CHF. Right is the extracted fluid.
After Flush no. 5
And this is how it sounds like a few days later - no pump noise at full lock - ignore the tyre noise.
[video=youtube;Q7zZWO61zRE]http://www.youtube.com/watch?v=Q7zZWO61zRE[/video]
All done ....
Caveat - Do this at your own risk - as with any DIY.
Re: DIY - Power Steering fluid flush
well done!
what's next? maybe can jio those that are interested for a diy session.. :cool:
That would be cool !
Doing the spark plugs next ...... showed up on my radar after I saw the voltage stats of each coil / plug looking not so good .......
Je_taime;1063767 said:
well done!
Thx, these DIY are great. I agree with some we should have these DIY sessions/demos. It makes car ownership more interesting.
spark plugs shld be next. I saw youtubes but very hard to see clearly the steps to do.
The cover says 2.5 to 5 Nm , I guess that's the tightening pressure. How the F do you measure that? arga arga?
Use a torque wrench to be sure. So the Bristools comes with a number of ranges including the "light" ones.
I have another dumb question.
Do we call this fluid(ATF or Pentosin CHF) as "power steering fluid" or "Auto Transmission Fluid". is this the same fluid that lubricates the gearbox?
The ATF stands for automatic transmission fluid. And was used for power steering and gearbox.
Pentosin not for gearbox ......
Thinking of maybe organizing a DIY get together .... More details later.
P.s - Whoever doing - don't puncture the filter when poking around with the baster in the reservoir ......
igo88dev
