E60 Decat
motoxxx55
Tinking of removing the catalytic converter off the stock headers of my 05' E60.
Understd its a PITA to remove the headers...
Wana check if anyone has done it & what is your feedback after removing it.
If you wana take it offline, feel free to contact me.
Thanx
Victor
83889777
Re: E60 Decat
You going to cut the cat out and knock through? I notice the exhaust system is one whole piece. There is a few point for You to cut. You can find it under the pipe, there s a small dot as a marking for you to cut. Don't like the welding back idea. Please share how you going to knock through. And CO test will fail when inspection if I am not wrong.
Re: E60 Decat
As of most conti cars, gotta remove the 1 piece exhaust system down, open up, empty everything, weld up both the cats & reinstall the exhaust system back up...will take abt 3-4 hours to complete.
As for the inspection part, cant comment on it as its really sensitive.
Re: E60 Decat
Red_Bean_Bun;928241 said:
Don't think it's a good idea.........performance in questions.
Slightly sluggish when moving off from stationary but great for mid & high end powerband.
Re: E60 Decat
With PB installed, no low end loss. And you will Love the mid high end!!!! The feel is like never ending till you see red line!! :)
Re: E60 Decat
Will a sprint booster improve the sluggish feel at low end?
Re: E60 Decat
If it is just only decat, stock muffler, the low end loss is minimal. Unless you upsize the diameter of the pipe from catback.
Re: E60 Decat
Decat & with a lta-compliant Sebring muffler will have noticeable or min low end power lost?
Re: E60 Decat
Why installing after market muffler will suffer low end loss? After market muffler provide better flow(straight through), and mostly will feel lighter pull off from stand still. It still retain the back pressure. Unless after market catback system(usually larger in diameter), non LTA compliant muffler also usually larger in diameter which produce louder sound.
Just decat, with lta compliant muffler. there is still a silencer in the center. No worry.
Correct me if I am wrong.
Re: E60 Decat
I think overall lose power.....but only a dyno will tell.
Go do a before & after dyno so you will really know the difference.
Re: E60 Decat
Will knocking thru both the cats disrupt the readings to the stock ecu, a/f ratio & fc? Or even cause the check light to be lighted up?
pg88comim
