E60 drl
Terras14
mine is a 05 E60 and i notice in idrive, there is a function to select Daytime Running Lights (DRL)
May i know what is the difference if i select that or not?
Reason being from my knowledge, DRl for E60 is bascially the Angel Eyes will light up. I can do that by tuning the knob from auto---->off---->on AE--->on headlamp.
So if i turn the know to the 3rd position, i can still have my AE lighted up so what is the use of DRL in Idrive?
Please kindly englighten me..thanks in advance.
Re: E60 drl
Terras14;632396 said:
okok after reading one of the thread titled features i dint know, i got the answer...
However just now i saw a F10, when he unlock his car, his AE lighted up automatically. Do we have this function in E60? many thanks,
Re: E60 drl
I think when u enable the welcome lights the AE will light up when u unlock.
Re: E60 drl
hi terras, this is only a feature in the facelifted XL versions of the e60.
from june 2007 onwards....
Re: E60 drl
Fr my 08 e60, when I switch the light button to auto, whenever I unlock the door, the AE n the eye brow will light up light.. Hope tat helps..
Re: E60 drl
Terras14;633892 said:
Hi may i know for the DRL to work, should i leave the knob in auto or??? thanks...
If u hav set DRL Onz in Yr idrive setting, it will Onz automatically once you have started Yr engine..
Re: E60 drl
Hi, i have set the to Onz in idrive but when i start the car, it DID not ONZZZ :(
If i set the knob to auto, everything sure ONZZ
If i set to off, everything is OFF
If i set to side light, AE will light up but dimly
If i set to low beam, everything comes on again....according to manual, to activate DRL, i should set to this but if everything were to come on, there is no need for me to activate DRL in Idrive so i am very puzzle
So when is DRL considered activated till now i am not quite sure...haha
Re: E60 drl
Maybe u wan to send bk to check?
Cos fr mine,
If I hav ticked the DRL, when I on the engine, the AE will automatically light up even though my light lever is at off..tat how DRL works.. I guess.. Light nt switched on but DRL still lighted up
When I set to auto, if on the bright day, same.. Oni the DRL will light up.. The rest of the light won't.. Unless encounter dark area then other light lighted.. Tats how a auto function shd work..
Hence DRL is considered activated when u start Yr engine n u din on Yr light the AE still lighted up..
Re: E60 drl
Cos fr mine,
i see bro, thanks. My DRL surely got problem....i tried in fact last night and set DRL to on and light switch to off. Start engine nothing happen...i like a idiot on and off engine then keep running in and out to check the AE....can i go to outside workshop instead of PML?
