My car, E60 yr 2007 is having this problem. Only happen once when you start the engine. Leave the car alone for a while and try restarting, you can hear a soft thud. Sometimes, it is a loud clank or jerk. Also depends how the car is parked in a flat ground or slope...The intensity of the thud, jerk or jolt varies.. It seems like it is trying to engage a gear when starting...PML did a complete re-programming but problem still persist. PML also mentioned that this is quite comment especially for LCI model. it seems to be a miscommunication between the torque converter and .and there is nothing that can be done except programming it. Other than this annoying issue when starting, the car run fine and I love my car. Just wanted to know if anyone is having the same problem...thanks
Asked my friend, Mr Google and it came back with this
"it seems to be a known problem for E60, E61 and E70s produced in 2007 and 2008. BMW issued guidance to service dealerships advising them to act 'on customer complaint only' rather than a recall.
It's a software fault with the transmission self-check test on start. I found this on another forum.
"You have a transmission control chip called EGS much like your DME that manages the engine. In fact they communicate with each other and often times the software update may be to both units. Software fixes to either or both would control shift points (up or down) at certain RPM, certain lateral accelerations (ABS sensor), braking force, hill holding, etc.
BMW issued as SIB (Service Information Bulletin) in December 2008, as follows:
SI B 24 08 08
Automatic Transmission December 2008
Technical Service
This Service Information bulletin supersedes SI B24 08 08 dated October 2008.
SUBJECT
E62, E70 with 6HP19TU - Transmission Clunks after Engine Start
MODEL
E60, E61 with N52K or N54 and 6HP19TU produced from 03/07 up to 09/08
E70 (X5 3.0) with N52K and 6HP19TU produced from 12/06 up to 10/08
SITUATION
The customer may complain about a clunking noise heard from the transmission, sometimes accompanied by a "bang", felt in the rear of the vehicle after engine start-up. This complaint can be intermittently reproduced when the transmission is in the P position (the noise and/or jolt does not occur when the selector gear is placed in N).
CAUSE
EGS software calibration in regards to the transmission self-check test on the engine start
SOLUTION
On a customer complaint basis only, check the vehicle's integration level.
If the integration level is:
On E60, E61 vehicles - E060-08-03-550 or lower
On E70 vehicles � E070-08-05-525 or lower
Reprogram and recode the complete vehicle with a current Progman version (V31.1 or higher). The target integration levels are E060-08-09-520 or E070-08-09-520, respectively, for E60, E61 and E70 vehicles"
SI B 24 08 08
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
SOLUTION
