E85 BREMBO 6pot Front 4pot Rear used E85
Re: E85 BREMBO 6pot Front 4pot Rear used E85
What size is your rotor ?
Sart.
Seller have a limited edition BKK custom made for his E85 ?
Available to view for yourself. I will measure the rotors later when I am home. Provide ur number for whatsapp pictures if interested.
teu_fel666;1000428 said:
Used Full set Original kit set Made in Italy with serial numbers for E85 red Brembo 6 pot Front 4 pot rear for sale 6k. Rotors and pad 95% new. View to believe. This is not after market brembo.
362mm front rotor 345mm rear rotor
Jason8822;1000848 said:
Sart.
Bro u may be the expert for E85 and would you be so kind to evaluate this brake set for me. I know the GT sets are selling for the following quoted by some seller here. Thanks.
i. Brembo GT brake kits Front Axle - S$6,260.00/ set
Piston: 6
Disc size and Type: 355 x 32 2-piece
ii. Brembo GT brake kits Rear Axle - S$5,630.00/ set
Piston: 4
Disc size and Type: 345 x 28 2-piece
excluding 7% GST.
These look like it came off a Porsche............
But who knows .......
The rotors dont look Brembo at all. Calipers are identical to Posches.
Ya, Brembo only made 4pot for E85 front...no 6 pots
Finally found out that the kit set is for Porsche fitted for E85 from the workshop. Any takers for the whole set at 5.3K.
BettyLockwood
