E90 320i Rims Advise !
BMW-GK
Hi All Bros,
Need some information pls be patient, a quite new to E90 320i PFL...
I am thinking of changing my current original 16" rim to at least a 18" or 19" when my tires worn out soon.
Not very keen to change to other brand of rims, dun know y, just want BMW rims (Original).
My question is:
1) Which BMW rims you all are using that flush with the body ? Model and off-set (NO Spacer)
2) Which BMW rims is forge and E90 can fit ? (the M3 rims?)
3) What will be the FC like after changing from 16" to 19"?
4) What off-set should I get to have a flush look (if not BMW Rims) Dun want to use spacer.
Thanks for your kind advise...
Re: E90 320i Rims Advise !
M3 rims will sit flush but you will most likely need to roll your fenders
Spacers are definitely needed for most other rims as e90 30s offset do not sit flush just but itself.
Best is get tireshop to help and see visually.
ok365t2com
