E90 325 throttle body on 320 N46 engine
Re: E90 325 throttle body on 320 N46 engine
apparently its the same just the bore is bigger. Saw it for myself today, but not sure if its worth the 800bucks
I personally don't think its worth spending $800 for a bigger TB unless you have already upgraded your intake and exahust (the TB is now the bottleneck).
say with intake and cat-back exhaust, what kind of gains will i be looking at for a 4pot n46
it wun be much for ur $800 mi thinks... unless u think its ok, maybe slightly better throttle response
Slightly better throttle response and alittle smoother pick up at high speed.
Dyno tested ard 8-10 bhp (ST Power)
CAI and Exhaust done before TB
wow....if 8-10hp is pretty good.
a remap can get u abt 10hp for 1500bucks
this is pretty value for money haha
hrmmm....
Hey silver...u did liao?:evil:
bump for this old thread
air scoop + BMC F1 filter + E90 325 throttle body + Eisennman exhaust = sibei swee setup for E90 318/320 4pot from in-to-out ???
wah, new idea siah! TB the way to go???
an ni kuan dunnid do ECU remap liaos...
:p
haha ... ECU remap is still the best la because the parameters are tuned by experienced tuner
scoop + aftermarket air filter + exhaust are just physical parts that improve the quantum of input and output but ecu is the master brain that control everything :D
eh i rem one post u send me before tell me dun bother about ecu liaos leh...
yeah .... i sure did because i believe ecu tune for 318/320 has no much effect unlike 325 which is 6 pots
kow jai na. kor kun krub.
ST power got do BM mod? sounds like a good mod. :)
i remembered the last time i bore the trottle body on my toyota the whole car like higher consumption and slower pick up leh.. after all the mods do tuning again?
The truth about this throttle body is that it does not work as a real one. This type of engine has valvetronic which operates as throttle body. Several millimeters will not improve anything it will be just like before but I doubt that 325i one will fit on N46! The fitting holes are not on the same radius!
P.S. the TB works as convenient one only when the valvetronic fails and the car goes in limp mode or safety control operation
thanks for sharing this info.
