Re: E90 Stabilise yet?
I was like you when I first read all the horror stuffs here posted previously but I was in worse situation tha you, I already booked my car :screwedu:
My E90 is 3 months old. This is my own experience since.
No problem with engine start/mirrors/seats memory....or whatever mechanical problems.
Sometimes the wipers are noisy but thats due to the wax left behind on windscreen after I washed the car. After using 'mama-lemon'
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
to wash the windscreen, there is no sound thereafter.
There is some slight rattling from my rear right door. The sound comes from the area between the doors exterior and the door handle within. I suspect something was loosen and its not a big issue bcos it only comes on when I drive fast and when I put a palm over that area, the sound is gone. It may also be due to a car vacuum cleaner i had in the boot which transmit the sound into the cabin. I need to investigate more.
I ve driven the car in almost all ways. Use the step tronic gears as well and rev it up to above the 5k rpm mark. Mine is the 320i and admittedly the car feels heavy when 5 passengers are inside, but the sports mode will be able to help overcome whatever lag there is. I ve also let a few friends of mine who drives other cars tried my car. They all think the BMW really feels good to drive:woowooo:
In short.......NO PROBLEMS AT ALL with ENGINE. Like the CAR veyr much.
