Engine oil top-up Qn
t3bkmzd
Hi
My ride's a e46 sedan and recently amber engine oil lit up for one short ride, subsequent drives it ceased to lit.
Checked my engine oil level and level is at lower mark thus assume its time to top up. How much should i top up? Bought 1 L of Mobil 15W-40 ... whole bottle pour in?
Quite sure this not the proper forum to pose qn ha. Pardon me
rgds
mel
Re: Engine oil top-up Qn
t3bkmzd;625191 said:
Hi
rgds
mel
it is usually 1L..
my E90 has the same issue (oil check light on) nearer to the servicing date...so i just top up 1 litre as the on board electronics advise...after that no more light and everything back to normal...if u read thru some postings here, it is quite common to top up engine oil in-between servicing time...so relax bro and enjoy your ride
Hi
rgds
mel
BMW engines are notorious for consuming engine oil. As long as there are no oil leaks you shld be fine.
How far have u driven b4 u needed to top up 1L of lube?
good88wine
