chrislim2568
Hey guys can someone please advise y after top up 2 litre of engine oil and the sign of the engine still showing 1+???
Sent from my SM-A510F using Tapatalk
Normally after you top up, let the engine run awhile then check the oil level.
Is the floor below your park vehicle have lots of oil stain?
Is the engine area coated with black oil around the seals/joints?
==> minor/major leaking
If no visible stain, try this:
start engine and idle for 15-20min
ram the accelerator hard (gear is at P!!!)
have someone observe the exhaust.
If lots of WHITE smoke, then engine oil is leaking internally INTO the engine
==> suspect valve seals or other type of internal seals worn
==> go to any of the site sponsors for diagnosis and servicing
If none of the above, are you driving a V12 engine????????
Hi, I just realized that I top up the engine oil 4l but the indicator isn't show full ... is it normal ?
What's do you mean ' should be overfilled ' ? I top up the engine oil because the triangle yellow displayed engine oil +1L left
No, I top up about half first and later the engine oil screen still shown half so I top up finished it. Strange thing is that I've checked the floor there isn't any leak after 4hrs parked
Even the engine oil is full, should the indicator show max ?
