mrkeke
Hi GURUS! problem is that the whole car vibrates excessively whenever I engage either the forward (D) or reverse (R) gear from stand-still position. Same thing happens when I stop in traffic and the gear is in D position of course with the brake pedal down. However the vibrations diminish the moment the car starts moving.
The idling rpm is about 700 revs/min. This is when the car vibrates badly on D or R gears. The entire car vibrates and can be felt by all occupants irrespective whether the engine is cold or hot. Noticed that the vibrations tend to subside when I increase the rpm to above 800 revs/min by softly stepping on the gas pedal while keeping the brake pedal down. Turning on the A/C lessens the vibrations noticeably.
