F10 Bluetooth
st8800
Guys
Not sure if u all have same problem as me.... the bluetooth will not be able to receive calls on the steering wheel button unless already used one time at least in making or receiving calls. I read last time the problem exist but not sure anyone has found solution yet. Software update from PML?
Re: F10 Bluetooth
I don't experience this problem on my F10.
Usual procedure is start the car, a few seconds later the phone is connected and ready to receive or make calls.
Could it be the phone you're using? I'm using iPhone.
Re: F10 Bluetooth
st8800;836714 said:
Guys
I have the same problem too. Must answer using the iDrive buttton.
Re: F10 Bluetooth
Same for me....It works sometimes and sometimes it doesn't work and I need to use the iDrive button instead.
Re: F10 Bluetooth
i press the roller! it works!
Re: F10 Bluetooth
Steering wheel button usually works for me.
However, I have problems getting the internet to work. How do you activate it? My iPhone is already connected to the car via bluetooth (hence can listen to music and receive calls etc). But when I tried to activate internet (even after allow data transfer by pressing the Options button), it won't connect to internet.
Any bros out there can help?
Re: F10 Bluetooth
Haha.....I also can't get my internet to work even after connecting my iphone via bluetooth.
No one can be as jialat as Ah Wing. After connecting his phone to F10 bluetooth, his james bond ride will auto call to Germany HQ! Hefty phone bills!
Re: F10 Bluetooth
knn, u my buddy, picak all my lobang here..
affirmative, my james bond ride has been pairing with my blackberry and is updating my idrive system through germany HQ with 001 IDD calls silently, seems like a common problem with bmw n blackberry. I am praying very hard now.
Re: F10 Bluetooth
cannot solve liao! need to change car.
Re: F10 Bluetooth
but i have the same problem as st8800, some times can ans via roller on steering, sometimes can only ans via idrive knob.
Re: F10 Bluetooth
Ahwing;836909 said:
i just did a cheaper alternative, i changed phone :thumbsup:
that a tough decision! sart respect.
Never picha yr lobang ler bro.. Help u to haolian IDD call to Germany is sap sap water for u.. Time to change car!!!
Re: F10 Bluetooth
never notice if the problem exist as i usually will use the idrive button to ans a call. will take note the next time....
st8800;836714 said:
Guys
Re: F10 Bluetooth
My F10 bloody bluetooth and iDrive used to hang, but ever since I got MA to do a software upgrade it does not happen anymore. Maybe go get your software version checked. PI can go to those sponsors who retrofit the 10" iDrive.
Re: F10 Bluetooth
Maybe can try to check the bluetooth software currently installed in the car and try to upgrade if appropriate.
when i collect my car(f10) the bluetooth software version are as follow, under iDRIVE, settings => software update :
Multimedia: MX-003.004.031
Telephone: TX-003.004.031
I downloaded the updated software from here, need the 7 digit vin:
BMW Bluetooth-Schnittstelle : Fahrzeugauswahl
The newer software version MX-3.5.4, and TX-3.5.4 has some improvement below. I do noticed the bluetooth connect faster with my iphone4s in my case:
> Office: Improved support for email messages.
> Telephone: Improved USB connectivity for
iPhones with iOS 5. Improved connection
setup with certain phones. Display and stability
with calls ongoing improved with certain
phones. Improved Bluetooth connectivity
with HTC phones. Improved phone
book sorting on Android phones in Japan.
> Multimedia: Improved display of additional
album and track information. Better connectivity
for Bluetooth audio devices.
Content of README:
http://www.bmw.com/_common/shared/owners/bluetooth/pdf/Readme_UPD01004_ENG.pdf
Size is about 6.6Mb download to root folder of the thumbdrive and insert into the USB centre console, then go to iDRIVE => settings => software update
it will select automatically the correct version to upgrade. upgrade takes about 3-5 minutes in my case.
Sharing my experience.
cheerss.. and happy motoring... :wavey:
Re: F10 Bluetooth
Apparently the big screen iDrive and the small screen iDrive function very differently. I have yet to try a big screen iDrive in F10 though.
Re: F10 Bluetooth
It is really a waste of time to get the internet connection working especially in Spore..the speed will bored u to death..if you are in korea or japan..this feature is value add.
vegas79download
