TezzaRed
Hello fellow F10 5ers
Just sharing some basic DIY maintenance information that I hope will be helpful for those of you who don't mind getting your hands a little dirty to ensure the quality of care for our Bimmers.
Today, it's a very simple and straightforward DIY on how to replenish your F10's washer fluid. It may seem simple ("just put water inside lor") but we have to take note that just putting water is not enough.
Washer fluids usually need some cleaning agents (eg isopropyl alcohol) to clean your windscreen, and the same reservoir is used to spray our headlamps as well. Hence it is important to use the right fluids to ensure that we take care of the windscreen and the headlamps.
First, when the reservoir runs low on washer fluid, your F10 display the error as shown.
You can also check for details on the error using your iDrive.
Get a bottle of concentrated washer fluid from any supermarket, petrol kiosk or car accessories retailer. I am using the 50ml LiquiMoly Washer Fluid Concentrate (made in Germany) that I bought from Autobacs for S$5.95.
Note that if you are getting a 1:100 concentrate (like I have), you will only need 50ml as our F10 washer fluid reservoirs are about 5 litres.
