F10 M5 side mirror
Dear Sifu,
Recently I saw a few advertisement was selling F10M M5 side mirrors. It that can plug and play On F10 5 series lci version. I believe the connector adapter was different.. some is 5 pins and 3 pins.
kindly advice.. possible can install?
Best to check with your workshop. F10 have quite a few variants some came with and without folding mirrors heated glass auto tilt etc etc. Theres no telling what you have and what that M5 donor came with unless you dismantle and check.
What I heard you can install it and only function from original car feature. Other than that side view camera and blind spot need retrofit and recording.
Don't see a point there. If you're paying so much for a USED set of M5 mirrors but only have the capabilities of your stock mirrors.
Installing the side mirrors on your F10 M5 is a relatively simple process, but there are a few things you need to keep in mind. First, make sure that the UTV Mirrors are properly aligned before attaching them to the car. Second, be careful not to overtighten the bolts when attaching the mirrors to avoid damaging them.
