F30 engine comparison
Re: F30 engine comparison
Feint;1034429 said:
Interesting read...
Paiseh if repost!
F30 320i vs 328i engines - Part number comparison - Bimmerfest - BMW Forums
Wonder besides pistons and a more aggressive tune , the power comes from where else.
That post is outdated. The pistons are different causing the compression ratio to be different. That post still says both are running 10:1 ratio.
It has been proven by opening up the engine and looking at the piston dome. The 328 is 10:1 ratio and the 320 is 11:1 ratio.
The higher cr on the 320 do not allow higher boost and it runs a different fuel mapping.
Basically, think a NA ENGINE with 11 cr. now u want to turbo charge it. U can maximum run say 1 bar. If u want higher boost, either use higher octane or lower compression by using thicker gaskets / change pistons.
x20i stock = 184bhp/270Nm = more than enough
those who desire for some more power
x20i conservative tuned (20% up) = 220bhp/320Nm = best bang for the buck liao
x20i conservative tuned (20% up) = 220bhp/320Nm = more than enough = best bang for the buck liao
vroom vroom..........
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
stock is the best ... wait kena stomped caught fire in expressway
Haha ...
Yeah lately keep seeing bimmers on stomp.
Ah yang, what you waiting for ????????
MTL
xocdia88me
