False Ceiling Contractor
ktnpl
I have an existing false ceiling / lighbox in my dining area and my master bedroom but there is insufficient clearance to service the air-con. I was advised to do an access panel for the two affected fancoil units. The dining area is using a wide fancoil unit and the master bedroom has a normal fancoil unit. My preference is calcium silicate board with aluminium frame. Anyone has good recommendations for contractor which specialises in false ceiling?
Re: False Ceiling Contractor
Hi ktnpl,
you can call Ah Bao at 9489 5485
HI,
Did you manage to solve your problem? I have the same issue...... :(
BMW2011;602583 said:
HI,
I have not done it yet but most designers recommend a recess instead of access panel. It is not easy to do an access panel due to odd size and odd corner of the fan coil unit, hence I may finally opt to do a recess.
okestreamtv
