Fault code (21A02D):Idle Irregular & (48077C):Wheel electronics, Battery life, front left
tommy_tan
New Member
Hi! Had a G30(520) with mileage 50K+. While doing a routine diagnostic, found 2 fault codes:
1) 21A02D: Idle Irregular. However, my RPM is stable and no rough idling or other symptoms. Search the web and found that it may be a false code which require a software updates.
2) 48077C: Wheel electronics, Battery life, front life. NO ideal what is this code represent.
Anyone have similar experiences and remedy to share?
Thks!
Tommy
Thks!
Tommy
Hi Tommy,
Recently, I got the same error codes while doing routine check up on my 5 series.
Can you please advise me with the solution if you came across any?. Thanks in advance.
