FS: E46 M3 Original Front Brakes
leokym
Looking to sell the above mentioned with rotors. Brake pads with 80% left.
$1200.00 (labour on me)
Interested, kindly pm.
Thanks..
Re: FS: E46 M3 Original Front Brakes
jimz33;407754 said:
Interested in your m3 brake. pls contact me to discuss 92715898
Sure.. Will contact you tomorrow morning.. thanks..
Just to add on something as a couple of bros asked for the rear brakes as well.. I will be most glad to sell together personally but for non m setup, its not recommended because the rear brakes is not the same. Alot more installation work to be done bcos of the hand brake factor. Off records, its more than enough stopping power unless your ride is modded with m54 with sc high boost or higher output, else no need to spend unnecessary $$$ for the rear.. yes to the bro that asked, its cross drill original rotors by default.. FCFS basis..
niteblu;407914 said:
nope.
the e46 m3 doesnt come w/ brembos in original state.
thanks for replying..
For all m cars, the brakes only comes with ONE big pot/piston... Not 2, 4, 6, etc, etc.. :)
Are your carriers modified to fit non M cars? The stock M3 front carriers are not a perfect fit for the standard E46 knuckles. You will need to mill a little off the carriers for them to fit the discs perfectly.
zbetvote
