Product LINK
Output Power RMS / Max:
at 4 Ohms 8 x 55 Watts / 110 Watts
at 2 Ohms 8 x 70 Watts / 140 Watts
Frequency response: 20 Hz - 22,000 Hz
Number of inputs: 4 x Highlevel, 1 x Aux, 1 x Optical
DSP resolution: 56 Bit
DSP processing power: 172 MHz
Total harmonic distortion (THD): < 0.02 %
Signal-to-noise ratio: > 100 dB
Damping factor: > 100
Input impedance: 30 Ohms
*Come with harness all you need to do is take out your stock amp and replace with this.
REVIEW OF THE AMP
Group buy from Bimmertech USA.
Each piece is $690USD excluding shipping
Shipping will be determined later.
Buyer:
1. Williammm
2.
3.
4.
5.
Will close once hit 5 pieces.
- Proprietary Class HD Technology for peerless sensitivity and minimal heat generation
- 8 separate configurable amplifier channels for maximum flexibility
- Extremely powerful DSP with virtually limitless sound adjustment options freely configurable via PC-Tool software
- 56 Bit DSP technology and 24 Bit AD/DA converter from BurrBrown
- Optical S/PDIF input 6 – 96 kHz with an integrated sample rate converter
- USB-on-board for direct connection to a PC
- Freely configurable 2-channel PreOut for the connection of additional amplifiers
- Aux input with automatic or manual switchover
- Start/stop capable down to 6 Volts supply voltage
- Latest D/A converter-controlled P³S power supply technology with "ECO Mode"
- Plug jack for optional cable remote control, functionality configurable via PC software
- State-of-the-art SMD technology for a more compact design and maximum reliability
- Six-layer printed circuit boards in multilayer technology for the best possible power and signal trans mission
REVIEW OF THE AMP
Buyer:
1. Williammm
2.
3.
4.
5.
