Hey guys,
Would like to share my experience using the above product, which is easy to use, leaves a brilliant shine, beads water...
Have been using it on my ride for 7 years, yes, since day 1.
It is water based, non-toxic, wax free and saves the environment as well.
Can tahan bird droppings, hot sun, upto +300C.
Simply clean off any grease, tar, dropping etc. ie. surface should be clean.
I usually clay the surface with shampoo to get a real clean surface.
Then just spray, wipe, dry.
It saves water as well, government is pushing every drop counts....like petrol.
It is expected that water will cost more than petrol by 2050, but I will be too old to tell the difference then.
As long as whiskey is still affordable, who needs water?
After application, time & water will be saved because dirt will easily be removed during washing, and energy can be better used for other stuff around the house.
In conclusion, please let me know if you are keen to know more about my cleaning regime or GB for this product from Germany. PM: +65 96339131
Thank you
Regards
Thank you
Regards
