gfb dv diver valve for bmw n20 (bnib)
lance666
Keen pls sms 81982228
Go Fast Bits Diverter Valve Upgrade T9357, BMW N20 228i / 328i / 428i
GFB Blow Off Valve - DV+: GFB DV+ Diverter Valve is a direct replacement for the factory valve (Patent Pending). Keep what works and replace what doesn’t! By retaining the factory ECU control and recirculating the vented air, the DV+ is a purely performance-oriented product that offers the following benefits:
* Sharper throttle response * Faster boost recovery on gearshift * Solves boost leaking issues * Built to last
This Direct fit replacement for the factory diverter valve uses the existing solenoid with TMS advantage.
Works with stock hardware, improves performance and reliability. Exclusive pilot activation system allows HIGHER boost pressure. The end result is sharper throttle response, lightning-fast valve actuation, and the ability to hold as much boost as you can throw at it.
The OE solenoid itself is great- the ECU opens it faster than any pneumatic valve so why replace it? The only valve on the market to solve the problem without flutter, excessive cabling and extra parts, installed in half the time at more than half the price.
WHEN you want no noise, no nonsense, just performance.
pg88comim
