GFB DV+ Diverter Valve Kit Installation
Seraphblade
Anyone has managed to get this part installed in SG?
If so, please pm me the price and shop that did it. Thanks!
Re: GFB DV+ Diverter Valve Kit Installation
I had mine installed at Codewerz, after installing this, my drive train error code (after changing my boost and charge pipes) was resolved. For pricing, you can ask Tony.
Thanks for the info. I read that the installation is quite labour intensive and in some cases need the manifold to be touched.
Anyways, I am surprised that the dv fixed ur problem. I guess ur issue was a leak somewhere which was probably fixed during the installation of the dv+. The dv+ is supposedly to help hold higher boost (>25 psi) and actuate faster.
I always have the drive train problem whenever I touch the vacuum hoses, waste gate or charge pipes. If the error was transient due to the temporary removal and reinstall, they are always resolved with a restart of the car.
Not sure about other model, my F20 installs easily. It's at the turbo. Less than 5 minutes. It's best if you install it before you start your day so that engine is cool.
Running 25 psi? That's very high. Which tune are you running.
By drivetrain error code, do you mean Check Engine Lights came on or something?
U88store
