bengtoh2000
hi friends,
good recommendation. visit this website The Oil Behind 1,000,000 Mile Engine and look at product #132 oil treatment and #9000cj 5w-40 engine oil. This oil are to protect your engine , especially for hardcore racers. Limited stocks.
Redline Engine Oil - Single Quart (0.946L)
Available grade: 5w20, 5w30, 10w30, 5w40, 10w40 & 15w50
Redline Manual Transmission Oil & Gear oil - Single Quart (0.946L)
Available grade: MTL, MT-90, D4, High Temp ATF, Lightweight Shockproof, 75w90 & 75w90NS
Redline Automatic Transmission Fluid - Single Quart (0.946L)
Available grade: D4, D6 & High Temp ATF
Redline SI-1 Fuel System Cleaner - Single 15oz (443.6ml)
Redline Water Wetter - Single 12oz (354.9ml)
Motul 300V - 1L or 2L Bottle
There a mix-up in this shipment of Motul from my supplier. The 5w40 & 15w50 are 4T Factory Line but can still be use on automotives petrol engine as it also meets API SL & JASO MA spec.
Motul 300 75w90 Power - 1L Bottle
300 75w90
Motul 8100 0w40 Power - 1L Bottle
8100 0w40
Amsoil XL Series Synthetic Motor Oil - Single Quart (0.946L)
Available grade: XLM 5w20, XLF 5w30 & XLO 10w40
Amsoil 100% Synthetic Motor Oil - Single Quart (0.946L)
Available grade: ASM 0w20, ASL 5w30, ATM 10w30 & AFL 5w40
Amsoil S2000 Synthetic Motor Oil - Single Quart (0.946L)
Available grade: TSO 0w30 & SSO 0w30
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 MTG- Single Quart (0.946L)
Synthetic Universal Automatic Transmission Fluid (ATF) - Single Quart (0.946L)
Diesel Concentrate Performance Fuel Additive (ADF) - Single 16oz bottle (0.473L)
Engine Flush (AEF) - Single 16oz bottle (0.473L)
Schaeffer Supreme #7000 - Single Quart (0.946L)
Available grade: 5w20, 5w30, 10w30 & 20w50
Schaeffer Supreme #9000 - Single Quart (0.946L)
Available grade: 5w30 & 5w40
Schaeffer 204 SAT - Single Quart (0.946L)
Meet ATF Spec:Dexron IIE/III,Mercon/Mercon V,Honda ATF Z-1/ SP-III ,Type T-IV
Schaeffer MolyEP Oil Treatment - Single Pint (0.473L)
Royal Purple Engine Oil - Single Quart (0.946L)
Available grade: 5w20, 5w30, 10w30, 10w40 & 15w40
Royal Purple Maxgear - Single Quart (0.946L)
Available grade: 75w90 GL4/GL5
Mobil 1 Engine Oil - Single Quart (0.946L)
Available grade: 0w20, 0w30 & 0w40
Mobil 1 High Mileage - Single Quart (0.946L)
Available grade: 10w30HM
Mobil 1 EP - Single Quart (0.946L)
Available grade: 5w20EP & 5w30EP
Mobil Delvac 1 5w40 - 1 Gallon Bottle
Mobil Synthetic ATF - Single Quart (0.946L)
Available grade: Dexron III & Mercon V
Pennzoil Platinum® Motor Oils - Single Quart (0.946L)
Eneos CVT Fluid
Chevron Supreme 10w30 (ISOSYN) - Single Quart (0.946L)
DENSO IRIDIUM IK16, IK20, IK2OL, IKH20,IK22 & IK24 per set of 4 plugs
NGK G-Power Platinum BKR6EGP,BKR5EGP
NGK IX Iridium BKR5EIX-11,BKR6EIX-11,ZFR5FIX-11,ZFR6FIX-11,LFR5AIX-11,TR6IX
BKR7EIX,BKR8EIX,LZFR6AI,ILFR7H ,RE7C-L,RE9B-T
Nippon Micro Performance Oil Filter Made in Japan
Suitable for Honda: T62,Mitsubishi: T600,Toyota: T1636 , O1644,Subaru: T600,Suzuki: T502
Nissan: T3154,Mazda: T600,Ford: T600,Hyundai: 26300 35502, Chevrolet: 96 458 873
300 75w90
8100 0w40
Eneos CVT Fluid
