Goodyear Eagle F1 Asymmetric 2
check13
Gurus, is $1250 good price for 235/35/19 n 265/30/19?
Price includes
-Fitting of Tyres
-Balancing of All 4 Wheels
-Filling Tyres with N2
-Rubber Tube Valves
Re: Goodyear Eagle F1 Asymmetric 2
Price includes
-Fitting of Tyres
-Rubber Tube Valves
Lemme help you to rephrase your question:
"Gurus, is $1250 good price for 235/35/19 n 265/30/19?"
The "inclusions" of "fitting of tyres, balancing of all 4 wheels, filling tyres with N2 and rubber tube valves" need not be mentioned as they are complimentary for the mainstream shops.
Since we are already reaching the end of 2013, any tyre before 2012 i will not accept it.
1250 nett or still must add gst?
A simpler answer is to check with the reputable tyre shops for prices of the same sizes.
$1250 for your sizes seem ok. Goodyear AS2 is one of the top tyres! Good choice.
Your choice seems a little big... recommended sizes for F30 are 225/35R19 front and 255/30R19 rear.
Actually too broad a tyre will slow your acceleration slightly and increase fuel burn. I'm going for GY AS2 235/45R18 after my first set of RF worn.
One brother use 245/40R18 all round (slightly smaller and indicate higher than actual speed) and did very respected time at Sepang recently.
Your recommended sizes are based on what wheel width?
235/265 is right for wheels between 9.5 to 10.0 width. If you fit 225/255 on 10.0, the tyres will be stretched.
235/265 is right for that wheel width
225/255 is right for BMW OEM factory specifications
225, 235, 245 R18 all on stock 8" rim. Within range.
For staggered we need 8" front and at least 8.5" rear, if not 9".
How do you know TS' wheel sizes?
It's E90 i'm driving la.
Better for E90 320 to use smaller tyres - too wide will slow acceleration.
69vnarchi
