Re: hello guys!
Mizzeecustoms is at it again,
Nike SB Dunk High Womens, and this time puts some finishing touches on the Infrared Air Max 90. Starting with the color, Miz dyed the entire upper black, including the Nike Swoosh. An Air Tech Challenge 2 print ?has been added to the mudguard?in infrared as well as volt yellow accents. The tongues have also been updated to reflect the look on the Agassi’s with the tennis ball flying on it. Finally,
Nike Dunk Obama, white outsole match the white inner toe box and the rear ankle padding. If you like what you see, head over to Addicted To The High for some additional custom work.
Available now at CaliRoots is the Converse Star Player Leather Mid “Sock”. The shoe is a take on the classic Converse basketball shoe and even features an old style tube sock attached at the ankle. The upper is dominated with white leather and uses the same outsole and toe cap found on the Chuck Taylor. A navy blue suede logo appears on the side panel and ties together the navy blue strip in the tube sock. If you are into the old school look,
Nike Trainer 1 Low – White Club Purple-Metallic S, these will definitely fit your fancy. They are available now at?CaliRoots.
The Nike Air Max Classic BW has seen a lot of attention in 2010, but here we have something new for you guys. Nike decided to make the shoe the latest victim of their blending techniques,
Nike Michael Jackson, combining it with elements from the classic Nike Air Max 95,
Nike Dunk High Womens, creating the Nike Air Max Modular 95 SI. The shoes feature the classic Air Max 95 colorway,
www.sbdunkstore.com, which is highlighted by neon accents. Word has it that they’ve started making their way to Footlocker accounts, so check with them for availability.
