Hi Guys!
Nid yr advice & expertise..when I start my engine, sometimes it ignites then stall..anyone encounter tis before? It happens after engine has cool off for a while, if I drive it around then try starting it's ok. Also looking for a E46 coupe meter cluster, think my engine temp gauge is gone. It hovers ard 3/4 of the gauge..had it chk and turn out faulty, actual is at half. Jus done inspection II and change all thats necessary..Idle valve & Fual valve also changed. Thanks!
