Help needed re: tyre size
MapleLeaf
Users Awaiting Email Confirmation
The last batch of E46 4-door uses 225/45 + 245/40 staggered wheels.
Can I change all four tyres to 225 size, using the same rims? i.e. are all the four stock rims the size size/ spec?
Re: Help needed re: tyre size
Hi MapleLeaf,
What rims r u using? Of coz u can use all round 225....however, if u r not using staggered size, I would recommend 235 all round instead...however, it might affect a bit on your petrol consumption.....:cloud9:
Bmer,
thanks for your quick response. I am using the stock 17".
I have always thought that I could switch to all-round same size tyres. The reason why I ask is that yesterday morning, I went to change to four pieces of brand new 225 tyres. Last night, I went for a drive to test the claimed quietness of the tyre.
Unfortunately, at 120km/h along ECP, one of the tyres came FLYING OFF the rim!
Sounds bad.....can't even imagine how the tyre can fly off....hmm.....Is your car alright...:whythis:
Sounds bad.....can't even imagine how the tyre can fly off....hmm.....Is your car alright...:whythis: Which tyre shop u went to? If is me, I will be damn piss man.... Hope nothing serious happen to your car...
Mapleleaf
First of all, i hope you are ok...That was a serious incident indeed.
For your guide, u should always be easy on your tires if they are just mounted on the rims. Let the tires sit in first for a few days driving...
Ok back to your question.
Your sports edition came with a staggered rims set up so ideally, u shouldnt really use the same all round sizes in your next change. I am not saying that it's bad or anything but you should try to optimize the set up you hv been given from the factory.
I believe your rims sizes are 8J and 8.5J and in that case, at least u do 225 and 235.
Afterall, I do find staggered set up for RWD car is nicer to drive:)
Wa lau eh, this is serious man.....u r a very lucky dude !!! Only seen these happening on F1 and thats scary ! what more to a saloon car.....
I read yr post 3 times trying to figure out how this can happen coz coincidentally i run 225's also on 8.5j rims and curious to know.
Was it the rear tyre that came off ???
Jack : Im thinking whether if its got anything to do with the tyre profiles ???
Rastaman
I doubt it...the tire shop guy can't be that dumb to put in the wrong profile for the tires.
It's probably just a faulty tire or was driven too hard before hand...hmm...
I accepted the shop's explanation that it is a one-off mis-judgement on their part (worker).
To clarify, it's not the whole wheel that came off, just the rubber tyre dislodged from the rim. Bad enough though. I had such a shock of my life that I panicked, and call BMW Service hotline for help (was Saturday night). They asked if I have a spare tyre. In the after-shock, I forgot that I have a spare tyre.
The tyre has been replaced. Rim checked for wobble and balance. Dipped in bath-tub for bubble-check. All OK. Life goes back to normal! Just another learning experience.
TripleM (and all others), many thanks for your feedback. These are times when I wish we could go live on MSN... there were so many questions that were in my mind when I was changing my wheel along the ECP. And I always remember the statement that the only link between the driver and the road is the tyre. That was why I changed all four tyres instead of two.
Thanks TripleM.
hb88covn
