I am driving a 2017 BMW 318i and recently experienced an intermittent hock issue. 70% of the time the honk does not work be it how hard i pressed.
Anyone has such experience and what is the likely problem?
I prefer honk because if really give people a wake up call...i personally feel more effective.no need honk, use high beam instead
Thanx for info, i will try to meddle with it but hopefully the airbag won't activate....HEeeee.Most probably is a wiring issue. The horn does not work mechanically in the sense that it works by the amount of pressure exerted.
you can try DIY to dismantle the steering wheel to trace the wiring or simple ws job. Good luck!
